Cutter rig for a Senior
John Slevin
Postby John Slevin » Fri February 11th, 2011, 3:31 am
Hello all and probably Chris in particular
My Email enquiry to Chris did not get away so I shall ask here and hope for the best.
Can anyone supply me with the dimensions of the headsails on Shellduck please?
Also for someone who does not like cold water, how does one get on the foredeck
of a Senior when the side decks are so narrow. Mine will be at least 3inches wide
(approx 75mm if you think metric)?
Regards to all
John Slevin
Hobart
Re: Cutter rig for a Senior
Postby chris s » Fri February 11th, 2011, 10:35 am
John Slevin wrote:Hello all and probably Chris in particular
Here you are
Number 1 jib is
Luff 13' 9"
Leach 12' 8"
Foot 7' 6"
Number 2 jib is
Luff 13' 9"
Leach 11' 0"
Foot 6' 0"
Over the top of course!
I think mine are even less than that.
Postby chris s » Sat February 12th, 2011, 10:52 am
What about trying this for a sail plan?
She is for sale here
http://www.boatsandoutboards.co.uk/view/NPC024?utm_source=AllBoats.com&utm_medium=dynamisch&utm_campaign=AllBoats
And is described as a
Yachting monthly senior 16ft
16Ft double chine two berth cruising yatch with centre plate
Built from plywood in the 1950s by the disigner Kenneth Gibbs
Originally a mast head bermudian sloop, she was newly rigged as a gunter yawl in 2001 with Douglas fir spars and cream terylene sails. A pocket classic in need of some attention including a lowrance x-23 echo sounder and fishsinder
Users browsing this forum: No registered users and 3 guests
