Is there an easyway to find the waterline
Posted: Tue April 18th, 2006, 1:52 pm
Hi
I have been slowly doing repairs and refit to my fibreglass Waterwitch.
I took 6 weeks off work to do the job. And that was 18 months ago. The job kept getting bigger and the available time smaller.
One of my problems was that there was a lot of rot in the decks. So I had to cut out big sections of the deck and replace the ply and re glass. Not so bad but what I didn’t realize at the time was that the fairing ( Polyester Bog) was coming unstuck all over the boat. Eventually I had to removed every bit of Bog back to bare glass all over and have since re faired (this time with Bog made from Epoxy Resin).
Now I am the stage of getting ready to paint the boat and was wondering if anyone had any tips on finding the waterline. I have read that you can use a hose full of water as a level. I have also seen Laser Levels at hardware stores. I think both of these assume that you have some reference point to start with and that the Boat is level.
The only reference that I have now is the rudder - looking at old photos I think I can guess where the water level was on the rudder so if I use this as a starting point I should be able to take this level all the way to the front of the boat using clear plastic hose full of water as a level ?
I am a little worried that the boat may not be 100% on the level. It looks level but when it rains water does not run out of the self draining cockpit.
Any ideas - have you used any of these methods, or some other way to mark the water line.
Tim
(Waterwitch JoJo)
Tim
(Waterwitch JoJo)
