A previous owner had applied a bead of bathroom sealant in the forecabin to stop water coming into the cabin down the sides of the samson post.
I've explored round the samson post and having poked through the surface, there's pretty much a void where the plywood should have been.
Outside the area is covered by the bowsprit and samson post. Here's an overview of the foredeck taken when I was buying the boat...
Poking around today revealed the void comes right through...
Obviously the samson post is rather important, so I plan to replace it. It is stepped on the keel/stem. The thinking at the moment is to take out the post and cut back to good wood all round.
The deck teak seemed fine so I had planned to do this from below and epoxy in new wood. Then fit a new oak samson post. However, it soon became clear I was only going to be sure of cleaning out all the bad wood by attacking it from above, that meant the foredeck had to come up.
I'm taking things quite carefully as I'm new to this and don't want to do anything daft in haste.
It's a bit hard to pick out the detail in the piccy, for those who are interested, so I've linked it to the original (just click on the photo to get the full size version)
I've mostly cut back to sound wood except towards the bow above the anchor locker where I need to go further forward. Most of the rot has been under the bowsprit and along the central seam that ran aft from there. The central seam in the removed teak was directly over the central seam in the ply deck :rolleyes: so a teak king pank will definitely be going over that when it comes to making good.
You can see the rot in the forward deck beam, fortunately this seems quite limited. Other than this beam all the rot has so far fortunately been restricted to the ply.
I'm thinking it would be prudent to remove the bowsprit, to ensure I get everythign cleaned out, but other than the two bolts (the holes for which can be seen on the top surface) I have no idea how it might be attached. I would really appreciate any guidance on how a bowsprit is incorporated into the structure of an MG design. For example will the stem be morticed into the sprit, are there any other things to watch out for?
If anyone has any pictures or plans of how the sprit is fitted/removed I would really appreciate seeing them!
As always any observations or comments gratefully received!
Chris
